Pony motor carb, D6-9U
fred hogan
Send a private message to fred hogan
So, after a long winters nap, I'm firing up the D6. Pony motor not getting gas. Took off compartment where float located. Found the rubber or neoprene on top of needle valve half gone and loose pieces plugging opening. Cleaned out and put back together. Pony fired up 2d pull, but would only run with full choke and slightly above idle speed, but was enough to crank main motor for a run.
Where can one of those little rubber tips?
Fri, Apr 19, 2019 8:17 AM
STEPHEN
[quote="fred hogan"]So, after a long winters nap, I'm firing up the D6. Pony motor not getting gas. Took off compartment where float located. Found the rubber or neoprene on top of needle valve half gone and loose pieces plugging opening. Cleaned out and put back together. Pony fired up 2d pull, but would only run with full choke and slightly above idle speed, but was enough to crank main motor for a run.
Where can one of those little rubber tips?[/quote]
With out buying a carb kit, you might find a generic
Float needle that will fit, or be modified to fit with the float in the correct height.
Fri, Apr 19, 2019 8:32 AM
fred hogan
Reply to STEPHEN:
the more I think about it, where the needle valve above the float basically let's gas in, I cleared that out, so then, the motor only ran with full choke tells me some of those particles from the rubber off top of needle valve is clogging up downstream. Time to take carb off and really clean more. Otherwise if float needle valve doesn't seal, it should tend to flood.
Sat, Apr 20, 2019 6:34 AM
Reply to fred hogan:
are you sure the needle valve is working and letting gas in the carb? Perhaps the debris was from the tank or gas line?
Sat, Apr 20, 2019 6:45 AM
fred hogan
Reply to dpendzic:
I have an inline filter on line going to carb. No problem with gas getting to carb fitting. I'll have to check for gas in float bowl. The rubber on top of needle valve was falling apart when I opened it up. thanks for idea.
Sat, Apr 20, 2019 7:01 AM
