OT - Welding table
OT - Welding table
Old_n_slo
Send a private message to Old_n_slo
Ok, by popular request, here are some pics. I don't take credit for the design, because I purchased it on the cheap from Craigslist after looking for a welding table for quite some time.
The guy that fabbed this up was doing a small production run of metal bending, and thus some drilled and tapped holes are in the top. I'm loving that part as you can fasten stuff to it, or add your vice when you want to.
Want to move it? Just lift one edge and wheel away!
Dimensions are 2' x 4' and 3' high and the top is 1/2" steel plate. The bottom shelf is wood. There is some angle steel welded to the bottom of the tabletop and the legs will bolt into that on each of the 4 legs.
Folds up and out of the way when not in use (yeah....like that happens!)
Sun, Aug 19, 2012 10:58 AM
zootownjeepguy
Thanks for Posting! Looks like a HEAVY table (which is what you want for welding) and I like the design. Might have to whip up something similar (if I ever get that path to my welder dug out).👍👍
Rich Salvaggio
D2 5U9917
Mon, Aug 20, 2012 9:13 AM
