OT--Deere 120 excavator
beaver-flat
Send a private message to beaver-flat
I'm using my in-laws Deere 120 excavator and the fuel shutoff/open up solenoid is not working. They currently use a piece of baling wire to manually pull the solenoid open so it will run (farmer fix).
It's a 24v system with 3 wires going to the solenoid. one hot, one ground and I'm told the 3rd one come from the alternator. Talked to a local shop and the guy sorta remembers this issue in the past and they just wired the third wire into a switch to power.
Has anybody run into this on Deere equipment??
Fri, May 8, 2020 8:09 PM
[quote="beaver-flat"]I'm using my in-laws Deere 120 excavator and the fuel shutoff/open up solenoid is not working. They currently use a piece of baling wire to manually pull the solenoid open so it will run (farmer fix).
Has anybody run into this on Deere equipment??[/quote]
It’s possible that’s a dual winding coil with a high amperage “pull in” circuit and then a low amperage “hold” circuit. The coil may burn out if continuously energized through the pull in terminal. Have you checked for continuity through the terminals?
Sat, May 9, 2020 6:31 PM
