One cylinder Cat engine found
Showing 1 to 10 of 18 results
Philip
Send a private message to Philip
An old friend called a few days ago, said come up and take a look at what I bought. Weather was good today so I made the trip up north, through winding roads, pine trees and big rocks, back a dead end road, to his place. We discussed the fate of several jet trainers still for sale at the nearby airbase, a type he had once flown; and the engine trouble on the Avenger he once flew. Then he said come on out and take a look at this Cat.
Many new parts with it, it looked to me like someone was repairing this engine and never finished. Previous owner was Environment Canada. I have been around quite a few older Cat machines and didn't recognize any components. The decal shows the newer Cat emblem, so the age of this engine puzzles me. I was curious if there are other engines like this out there and just what it was used for. Any idea as to it's value. Any links appreciated too. Phil😊
http://s284.photobucket.com/albums/ll24/Phillyburger/Cat%20one%20cylinder%20diesel/
Wed, Feb 18, 2009 9:34 AM
side-seat
That's an oil test engine.
Wed, Feb 18, 2009 10:01 AM
deetwocat
Send a private message to deetwocat
Reply to side-seat:
side seat is correct it is a oit test engine cat had many of these to test differnt oils there is a gentleman that brings a couple to the tri. state show in portland in. but i think it is kind of rare.
Wed, Feb 18, 2009 10:21 AM
Lubricant and other testing. These were made to be torn down, wear measured and then rebuilt with new components for the next run.
http://www.acmocbb.org/ACMOC_BB/showthread.php?t=977&page=2&highlight=oil+test+engine
http://ohe.cat.com/cda/layout?m=85361&x=7
http://www.oldengine.org/members/diesel/Caterpillar/CaterpillarMenu.htm
Wed, Feb 18, 2009 10:24 AM
OzDozer
Philip - The Caterpillar Single Cylinder Oil Test Engine (SCOTE) was first built by Caterpillar in 1935, to provide a test base for oil quality and oil performance testing. This was done because Cat engineers did not believe that oils could be tested properly, just with bench testing, and other forms of testing such as chemical analysis.
The engine has been produced in sizeable numbers, and supplied to many oil companies and other lubricant specialists .. as well as car, truck and tractor manufacturers, worldwide .. and is still in use by Caterpillar today. These SCOTE engines have been purchased by companies as diverse as Daimler-Benz, GM and Ford.
It is an engine that can be dismantled, inspected and modified quickly and easily .. and which can be substantially altered, via changing various components such as heads, valves, camshafts, fuel systems, etc .. to provide results for different operating conditions and parameters .. and to provide results for different diesel engine designs.
Caterpillar undertake oil testing for any lubricant manufacturer, or any oil additive manufacturer, who wishes to get independent, Caterpillar-certified results on their oils. This process is lengthy and costly, and I suspect not many companies indulge in it, as much as they used to .. particularly since Cat have been producing their own branded oil.
In the ancient past, Cat tested any oil manufacturers product, if offered, and gave it their "blessing", by adding it to a list of "approved lubricant brands". This system has apparently been abandoned since Cat commenced production of their own brand of oils.
Other engine manufacturers such as Petter, have produced oil test engines, using a model from their single cylinder, 4 stroke diesel lineup, to produce oil test results similar to Caterpillar SCOTE results, but faster and cheaper.
SCOTE testing .. http://www.intertek-cb.com/ARL/caterpillarenginetests.shtml
Cat SCOTE engine at show .. http://www.youtube.com/watch?v=7A_0ztmOwQc
Cat.com engine history .. http://ohe.cat.com/cda/layout?m=85361&x=7
This following excerpt, by a lubrication engineer .. one George Leonard Neely (Chevron Corp, Ret.) .. from the SAE book, "The History of Aircraft Lubricants" .. gives an interesting insight into the development of "compounded engine lubricating oils" (i.e. - engine oils with performance-enhancing additives) .. which oils have become such a regular part of our lives .. that we forget, that at one time, engine builders and oil companies just refined oil as it came from the ground, bottled and canned it, and and poured it into engines without any serious modification.
It was only after the first Cat diesels had been in use for a year or two, that ugly oil performance (and therefore, engine performance) problems arose .. that needed the combined efforts of lubrication engineers, and engine-manufacturing engineers, to overcome ..
The history of aircraft lubricants .. http://books.google.com/books?id=QhEaoGYT4FIC&pg=PA77&lpg=PA77&dq=single+cylinder+Caterpillar+engine&source=web&ots=ctVQfiBYX8&sig=mGPivgDUrTg-OKf0ITqnZwCEYeM&hl=en&ei=ecmbSfbJE5LSkAWtgLWkBQ&sa=X&oi=book_result&resnum=3&ct=result#PPA75,M1
Wed, Feb 18, 2009 4:08 PM
Philip
Reply to OzDozer:
Very interesting reading😊 ,we take for granted the effort that now lets us run diesels for thousands of hours. I forgot to add that my friend will part with the engine. He hoping someone will get it back to running condition. You can e-mail him at: [email protected]
Wed, Feb 18, 2009 6:35 PM
gwhdiesel75
Reply to Philip:
Wasn't the engine that furnished power assist to the controls of a No. 66 pull grader (No. 77?) also a single cylinder gasoline engine? If so, how can you tell the two types of engines apart?
Wed, Feb 18, 2009 7:47 PM
ag-mike
Reply to gwhdiesel75:
the grader motor is simialr only because its a single cyclinder.
Wed, Feb 18, 2009 8:06 PM
OzDozer
George - The G800 that powered the power control graders was most certainly a single cylinder gasoline engine (of 8HP) .. but the oil test engine is a diesel .. and much, much larger in physical dimensions. I seem to recall it was 5¾" bore and 8" stroke? .. the same as the RD7 and RD8 engines?
South West Research Institute runs no less than 26 of these engines on oil test work.
Wed, Feb 18, 2009 8:15 PM
SJ
Send a private message to SJ
Reply to ag-mike:
I have seen a few of those test engines at tractor and equip. shows and one time I think it was in Greenville Ohio that I saw one that was made up from the D17000 V-8 Cat for the oil testing program.The other ones I saw were made up from the in line engines.
Wed, Feb 18, 2009 8:20 PM
OzDozer
Reply to SJ:
South West Research Institute runs a number of versions of the 1 cyl oil test engine ..
1Y73 is a 5.125" bore x 6.5" stroke engine .. http://www.swri.org/4org/d08/DieslTst/cat1m-pc.pdf
1Y540 is a 5.4" bore x 6.5" stroke engine .. http://www.swri.org/4org/d08/DieslTst/cat1k.pdf
1Y3700 is a 5.4" bore x 6.5" stroke engine fitted with a DI, 4 valve head .. http://www.swri.org/4org/d08/DieslTst/cat1p.pdf
1Y3700 can also be set up with an OHC arrangement and a high pressure electronically-controlled, fuel injection system ..
http://www.swri.org/4org/d08/DieslTst/cat1r.pdf
Wed, Feb 18, 2009 8:44 PM
