oil for D69U transmission
Showing 1 to 10 of 10 results
fred hogan
Send a private message to fred hogan
I have a waste oil burner in my shop, and one source is from a trucking company. Last year, they had a case or 6 gallon plastic containers, and one broke open, so the decision was made to throw the whole case away, 30 gal total. They put it all in a barrel and there were 5 unbroken plastic containers. It's 10-30 w synthetic oil.
Can this be used for my transmission and clutch oil for D69U? The manual just calls for straight 30 weight oil. fred
Sat, Aug 31, 2019 12:58 AM
kinda light for the trans but ok for the oil clutch. I wouldn't go less than 50W for the transmission.
Sat, Aug 31, 2019 8:29 AM
fred hogan
operation and maintenance instruction booklet calls for SAE30 for above 32 degrees F, and SAE 10 for 10-32 degrees, -10 and below dilute with kerosene. This is recommended for every compartment to include Final Drive, but which could be SAE 80-90 for final drive.
My question goes to whether oil with detergents or synthetic would be acceptable.
Sat, Aug 31, 2019 11:21 AM
bursitis
This is good advice. you should look in to the history and effects of Caterpillar oil recommendations.
Sat, Aug 31, 2019 8:00 PM
JackD6-5R
Reply to bursitis:
I run 80-90 gear oil in trans of my 9U works well.
Sat, Aug 31, 2019 9:17 PM
fred hogan
I plan to use the 80-90 in final drive transmission.
Sun, Sep 1, 2019 11:41 AM
fred hogan
Reply to bursitis:
I do plan to use the 80-90 in final drive. Where do I find this history?
Sun, Sep 1, 2019 11:46 AM
I don't know that it's all in one place, but in a nutshell, at some point in the late 60's or early 70's, Caterpillar recommended or at least allowed the use of 30 wt oil in all compartments of their equipment. I think the idea was to simplify maintenance and reduce cost of operation. I'm not sure how successful that ended up being, but I guess it did simplify daily maintenance at least.
Since that time, there have been so many improvements in each special purpose fluid/lubricant/oil that the benefits of using the best one for each use cannot be ignored. I use diesel rated motor oil for the engine, a universal/hytran/TO fluid for oil clutches, powershift transmissions and hydraulic systems and a gear lube for manual transmissions, final drives and other gear boxes. Viscosity of each fluid depends mostly on expected ambient temps the machine will be operated in.
Sun, Sep 1, 2019 11:39 PM
fred hogan
[quote="ccjersey"]I don't know that it's all in one place, but in a nutshell, at some point in the late 60's or early 70's, Caterpillar recommended or at least allowed the use of 30 wt oil in all compartments of their equipment. I think the idea was to simplify maintenance and reduce cost of operation. I'm not sure how successful that ended up being, but I guess it did simplify daily maintenance at least.
Since that time, there have been so many improvements in each special purpose fluid/lubricant/oil that the benefits of using the best one for each use cannot be ignored. I use diesel rated motor oil for the engine, a universal/hytran/TO fluid for oil clutches, powershift transmissions and hydraulic systems and a gear lube for manual transmissions, final drives and other gear boxes. Viscosity of each fluid depends mostly on expected ambient temps the machine will be operated in.[/quote]
Thanks for your input. My free supply of engine synthetic oil, 10-30 is probably no good for transmission and clutch, but ok for engine. So, when I go to Tractor Supply, what am I looking for in Transmission oil, like what is the equivalent of SAE 30 mineral oil or the MIl-L2104A oils? I'm sure Mil-L-2104 is outdated... Also, the final gears I plan to use 80-90, GL5.
Thanks, flyingfred
Mon, Sep 2, 2019 8:36 AM
Reply to fred hogan:
Thanks, flyingfred
I use 80-90 GL5 in my manual gear boxes--transmissions-final drives-etc
Mon, Sep 2, 2019 9:52 AM
cheshire cat
Send a private message to cheshire cat
Thanks, flyingfred
[quote="fred hogan"]Thanks for your input. My free supply of engine synthetic oil, 10-30 is probably no good for transmission and clutch, but ok for engine. So, when I go to Tractor Supply, what am I looking for in Transmission oil, like what is the equivalent of SAE 30 mineral oil or the MIl-L2104A oils? I'm sure Mil-L-2104 is outdated... Also, the final gears I plan to use 80-90, GL5.
Thanks, flyingfred[/quote]
I would be cautious I would guess the newer 10-30 will have friction modifiers so it might not be great in the clutch , a bit thin for the engine
and far to thin for the gear box , personalty I run basic old spec 15-40 deo in the engine and oil clutch and 90 wt in the transmission and finals
I think as others said the SAE 30 recommendation was for a short time and was soon changed back to more sensible grades that suited the different applications ...
Mon, Sep 2, 2019 1:49 PM
