Obstinate little 2-Ton
naylorbros
Thank you received: 34
My 2-Ton has always started quite well for as worn out as it is, but this month it has not been cooperative. I had finally had it with working on it in the tractor storage barn. I pulled it out of its spot and then carried it to the shop with the skidsteer. I think I might have lost the headgasket between cylinders 1 and 2 and cylinders 3 and 4. I have seen them burn through there before.
Wed, Aug 26, 2026 4:48 PM
Deebo
Librarian
Thank you received: 107
What a cutie! 😊
Thu, Aug 27, 2026 7:23 AM
