new Carb Floats in Cat carb kits
Eric Marshall
Send a private message to Eric Marshall
the new floats in the cat carb kits for pony engines are a porrous foam and assorb gas then sink to the bottom..........😕😞 found out the hard way when the when the cylinders kept getting raw fuel in them.......lost a few more hairs over this one ! put the old float back in..... no more flooding out😊
Mon, Feb 8, 2010 12:47 PM
Pioneer1930
Send a private message to Pioneer1930
This is kind of poor news to me I was just ready to rebuild the carb in my D2 and lose the old cork float thats coming apart and clogging my jets. 😞
Tue, Feb 9, 2010 7:23 AM
YeLLoIrOn
Send a private message to YeLLoIrOn
Reply to Pioneer1930:
just coat the new float in gas tank sealer and let dry for 24 hours. you'll be good to go after that.
Tue, Feb 9, 2010 7:30 AM
Eric Marshall
Reply to YeLLoIrOn:
never thought of the gas tank sealer..... that damn ethanol seems to eat everything these days . another thought, maybe see if Zeneth offers a ethanol safe float
Tue, Feb 9, 2010 8:03 AM
CarlsCAT
Send a private message to CarlsCAT
Reply to Eric Marshall:
Just found a bad float in my pony motor Zenith carb on my CAT 212 Motor Grader...It appeared to be some sort of porous material in a plastic casing...Bought a new float...looks the same...
I'm wondering about this cork float found in these other carbs...Haven't seen a cork float...I'm wondering if the porous material in the "plastic floats could be removed and a piece of cork put inside it...should the float go bad...The new float seems to be okay for now...Have to finish cleaning all the hardened oil/grease/dirt off the outside of the carb and cleaning all the jets and passages in the carb...
This pony had not been ran for some time...After the magneto quit...Even had to clean the governor real good too...Real dirty...lever not working...lever shaft stuck with old oil...
So, does anyone know where these old cork type floats are available ?...Or just have to make one ? ....
Wed, Feb 10, 2010 9:06 AM
