More pony problems
More pony problems
Sf1066
Send a private message to Sf1066
Well this poor pony must have had a tuff life before me. Among other things I found a crack above the main bearing thru where the pin goes. I assume this is not normal or repairable. But I thought I would get your opinion. Thanks. [attachment=59333]1DFEC574-5DF0-4BFD-AEC8-FEA048CE2EBA.jpg[/attachment]
Sun, Jun 21, 2020 6:08 AM
hfdzl
Is that in the bearing? Cracks in the actual block casting.also happen where the pin locates.
Sun, Jun 21, 2020 4:53 PM
bboaz
Reply to hfdzl:
I repaired the pony main bearings which move in the block because the dowel is worn and lets the bearing move in and out creating excessive end play in the crank. I made press fit main bearings out of brass with a .060 flange on the inside of the bearing so it would seat against the inside of the block and keep the bearing from moving in and out. The .060 flange on the inside of the bearing on both the front and rear bearing holds the crankshaft centered in the block and maintains a .006 endplay in the crankshaft. This can also be adjusted by the thickness of the gasket on the flywheel side of the block holding the flange assembly in place. The dowels holes which hold the bearings in place were worn out of round and the dowels just wobbled around in the hole. To fix that the hole was threaded and a new threaded dowel was made to screw in the hole and tighten up. In my case I used a 7mm tap to thread the hole because that was the next size larger than the .250 dowel. Both the bearings and the dowels were secured with bearing mount to keep them from moving. After the bearing mount had cured I tried to move the bearing and unscrew the dowel. Neither one would move. I don't think the crack would be a problem using a fix like this. The motor is back together and installed on a machine. Starts and runs excellent with the correct end play in the crankshaft.
[attachment=59370]20190424_111256.jpg[/attachment][attachment=59368]20190424_111249.jpg[/attachment][attachment=59367]20190425_142425.jpg[/attachment][attachment=59369]20190425_142306.jpg[/attachment]
Sun, Jun 21, 2020 9:55 PM
Sf1066
Reply to bboaz:
That’s a nice fix. I was concerned with the block cracked when it warmed up the bearing could move where ever it wanted. I will get serious about finding a crank and other stuff now.
Sun, Jun 21, 2020 10:14 PM
bboaz
Reply to Sf1066:
sf1066, in another thread, 9U d6 pony motor main bearings, started by me and referencing Uncle Riches fix of the pony motor bearings and end play, you will see what I did to determine the amount of flange on the inside of the bearing boss's for the bearings I made. I used the contraption pictured in the first photo to determine the thickness of the flanges on the bearings for the front and rear bearings. The second picture shows the contraption in place positioning the crankshaft so it is centered on the cylinders. I don't remember what the thickness of the flanges were but I was able to adjust the thickness of the flanges so crankshaft stayed center and still had an acceptable end play clearance. In my previous reply I said the flanges were .060 but I think that is what I started off with and once the crankshaft was centered on the cylinders, I made adjustments to this thickness. This repair was made to a D6 pony motor but I think the same thing could be used on your D2 motor.
[attachment=59378]20190420_140937.jpg[/attachment] [attachment=59379]20190420_140652.jpg[/attachment]
Mon, Jun 22, 2020 1:40 AM
Mike Meyer
Thank you received: 6
Reply to bboaz:
That's a really nice solution bboaz, and thanks for the extra pics that show how you centered the crankshaft, very interesting.
Mike
Mon, Jun 22, 2020 2:40 AM
