Material Supply
Material Supply
Showing 1 to 7 of 7 results
flmore
Send a private message to flmore
I went searching for some stainless steel tubing. Found a web site that had quit an inventory. Also you may purchase from 1" to what ever. My thoughts were O.K. Roller bushings, pin bushings.ect.
www.speedymetals.com
Floyd
Tue, Mar 3, 2009 1:10 PM
ol Grump
Using stainless steel for pins and bushings isn't a great idea as stainless against stainless will gall and seize up with surprising ease.
Tue, Mar 3, 2009 9:03 PM
egoman
Send a private message to egoman
Reply to ol Grump:
I have to agree with the OG on this one. We work with the stainless stuff all the time and we describe it as a metal that hates itself. If you ever get a chance to use it we will quite often put steel nuts on stainless bolts. Also lower grades of stainless are not that tough.
The BIGGEST thing in motocross
Wed, Mar 4, 2009 3:19 AM
Steve A
Reply to egoman:
easy way to make brass bushings is find something close from these charts and if you have a lathe turn them to exact size. This company only sells in bulk. Get the number and order them from your local bearing house.
http://www.anchorbronze.com/powertransmission.htm
Wed, Mar 4, 2009 3:31 AM
flmore
Reply to Steve A:
The stainless is for the steering on my 23' cabin cruser. Never ment to imply that stainless would be proper for a bearing.
Wed, Mar 4, 2009 9:59 AM
n7gxz
Send a private message to n7gxz
Reply to Steve A:
[quote="Steve A"]easy way to make brass bushings is find something close from these charts and if you have a lathe turn them to exact size. This company only sells in bulk. Get the number and order them from your local bearing house.
http://www.anchorbronze.com/powertransmission.htm[/quote]
I was looking at the C95400 Aluminum Bronze and wandering if it would make a good bushing for the pivot ends for my 2S dozer blade on my D2. What do you guys think?
Kevin
D2 5U13247 Direct electric start, #44hyd, 2S blade, Hyster D2N
Wed, Mar 4, 2009 10:24 AM
oldparker
Send a private message to oldparker
Reply to n7gxz:
Kevin
I ordered cored bronze bushings for my D2 front idlers from McMaster Carr. They offer them in a big variety of sizes. I took those to a local machine shop to have them finish machined. I also bought the 1 3/4" axle material from them. Of course, they have anything else under the sun in hardware items, and I do mean anything. They offer next day delivery is standard in my area. They are at (609) 259-8900. Hope this helps.
Thu, Mar 5, 2009 3:03 AM
Art From De Leon
Send a private message to Art From De Leon
Reply to oldparker:
McMaster Carr has EXCELLENT customer service. If you can ever obtain one of their catalogs, you can spend hours looking through it. They come up on eBay from time to time, the catalog on line is also good, but thinking of the proper name for what you are wanting, sometimes takes some doing. Everything I have ever ordered from them has shown up in no more than 2 days.
Thu, Mar 5, 2009 8:04 AM
