mag timing
mag timing
m rust
Send a private message to m rust
I need to know how to time my mag on my pony motor. This is a 5r d6 with the 4600 engine. I changed the condenser and got the rotor set wrong. It runs but it runs ruff and and dies.
Thu, Apr 4, 2019 7:14 AM
What kind of mag do you have?
I am familiar with the one on the 9u where the rotor will only fit one way.
Thu, Apr 4, 2019 9:22 AM
m rust
Not sure what mag it is. The rotor is like a gear that can go on anywhere on the mag. Lost my book so don't know where to point it. I cant even remember which cyl is number one.
Thu, Apr 4, 2019 5:18 PM
kracked1
Reply to m rust:
If you look closely at the teeth on both gears there should be a mark of some sort. I have seen two dots on the mag one and a clipped tooth on the rotor before.
Thu, Apr 4, 2019 7:06 PM
m rust
Reply to kracked1:
Ok thanks. Its been early 90s since i worked on the mag. 😖mile:
Thu, Apr 4, 2019 9:01 PM
