Late D4 brake pawl pin
Haus
Send a private message to Haus
I have to replace the brake pawl pin (3B1137). I can't see it listed on cat parts so assume it's discontinued. It looks like it's 3/8" X ~3" long. Part catalog looks like it may have had a cotter pin in one end(?).
 [attachment=74873]IMG_20240110_072836.jpg[/attachment]
[attachment=74872]IMG20240110073315.jpg[/attachment]
Assume I'll make a new one. Any advice on what kind of steel it should be made of? I need the brake lock to work as it's very steep where I am.
​​​​​​Paul.
Wed, Jan 10, 2024 4:45 AM
Haus
Late 6U I meant. Whoops.
Paul.
Wed, Jan 10, 2024 4:47 AM
Thank you received: 287
Reply to Haus:
Paul.
I would suspect getting some cold rolled would be your best bet, but see no reason why you couldn't get by with hot roll.
Where are you located?
That broken pin will be a fun job to remove. JM
Wed, Jan 10, 2024 10:34 PM
Thank you received: 62
You need to get the old part number into the computer age with the right number of 0 in the right place, which I always forget. Partly because my dealer still has some old time parts persons. Really needs to be pinned and in a prominent place on this board.
Thu, Jan 11, 2024 3:00 AM
Thank you received: 54
Reply to Ray54:
try as ray suggests for the part number. for example 5b624 would become 5b0624. the cat parts system is set up for 6 character part numbers
if you can't get one a grade 5 high tensile bolt will work just fine and coat the thing with a little copper or nickel anti seize it will lube it and prevent fretting corrosion.
any decent engineering supplies should also be able to supply a cotter pin the right size.
Thu, Jan 11, 2024 6:58 AM
Reply to trainzkid88:
something to remember one of the best brakes in the world is an implement and a stout tree.
Thu, Jan 11, 2024 7:01 AM
