John Deere Killefer offset disk harrows 1961
Showing 1 to 10 of 19 results
brian18a
Thank you received: 62
Perfect for Caterpillars as well as JD
Sat, Mar 14, 2026 12:27 AM
brian18a
Sat, Mar 14, 2026 12:28 AM
brian18a
Sat, Mar 14, 2026 12:29 AM
brian18a
brian18a
Sat, Mar 14, 2026 12:30 AM
brian18a
brian18a
Sat, Mar 14, 2026 12:31 AM
brian18a
Sat, Mar 14, 2026 12:32 AM
Thank you received: 270
Huge thanks to Brian!
I am very fortunate to own several 1100,1200 and HD wheel disks for my crawler collection. I tell folks that JD Killefer implements are proper for any Caterpillar on the farm. Very durable and perform well here in California.
Sat, Mar 14, 2026 1:37 AM
brian18a
I just a 12 foot 1400 series with new blades. Pictures after I get it home.
Sat, Mar 14, 2026 3:07 AM
Brian: Could we see the serial plate on it when it gets to you? I am under the impression that a 1400 series has the angle iron framework which is inverted, allowing it to trap dirt and debris? Also had provision for rock/weight boxes?
I’m not quite agreeing with the literature you shared? Misprint with a 1200? Thanks! JM
Sat, Mar 14, 2026 3:17 AM
