injector not working
1948catD4
Send a private message to 1948catD4
I just did an overhaul on my d4 and the injector on number 2 cylinder in not working the pump is working fine when i crack the line at the pump it is spraying fuel but no change in engine and when i adjust the lift adjustment screw i still get no change in the engine sound or running order what could it be not sure if it is spraying did not pull out of chamber to check .I had the injector apart could the breaking pressure be off? not sure what it could be . might be dirt in injector nozzle?
Tue, Apr 27, 2010 9:16 AM
Pull it out and install it out over the track or pointing upside down over the PC chamber and use the pony motor to turn the diesel over to check and see if it's spraying. If it seems to be spraying, then swap another injector from a "good" cylinder into that spot and see if the miss follows the injector or stays with that cylinder.
Most likely need to have the whole set adjusted for proper performance.
Tue, Apr 27, 2010 6:48 PM
1948catD4
I swapped the injector with another cylinder and it started working when i open the line on the number 2 pump the engine dosent change could the pump be bad? I have another pump will try that I think pump 2 and 3 are not working right as when i open 1 and 4 the engine strats to miss and change like they should when you open the lines number 3 doest it a little bit but not as much but i think it is best i haver the injector serviced and set right.im just wasting fuel and time trying to adjust them myself since I had the injectors apart should have left them alone. woulkd be farther ahead lol.... I just want to play and got lots of log moving and land clearing for her to do.any Ideas would be helpful.
Wed, Apr 28, 2010 5:31 AM
Dick Tucker_archive
Send a private message to Dick Tucker_archive
Reply to 1948catD4:
I had a similar problem on a D7-17A it turned out to be a bad injector pump on one cylinder. Go and purchase a replacement injector pump and move it around to the different positions until you find which one is bad.
Thu, Apr 29, 2010 10:30 PM
