Hyster D4 CB Donkey Hoist
Showing 1 to 10 of 10 results
qipp
Send a private message to qipp
I have a Hyster Model D4 CB Donkey Hoist mounted on a 1945 D4 that I have never tried to use. Does anyone have any experience with this setup? I don't know how to use it or what it used for. Can it be used like a towing winch?
Sun, Aug 4, 2013 10:01 AM
Can you post a picture of it?
Sun, Aug 4, 2013 10:38 AM
Reply to drujinin:
Here's some material to study up on......
http://www.alliedsystems.com/pdf/Winch/Manuals/599186W.pdf
Sun, Aug 4, 2013 10:25 PM
qipp
[quote="Old Magnet"]Here's some material to study up on......
http://www.alliedsystems.com/pdf/Winch/Manuals/599186W.pdf[/quote]
Old Magnet, thanks for posting the manual from allied, now I have some idea how it works. durjinin, here are some photos. It will cost a small fortune to cable 😆
[attachment=18804]DSCN0214.jpg[/attachment][attachment=18805]DSCN0215.jpg[/attachment][attachment=18806]DSCN0216.jpg[/attachment][attachment=18807]DSCN0218.jpg[/attachment]
Mon, Aug 5, 2013 5:12 AM
n7gxz
Send a private message to n7gxz
Reply to qipp:
What would that have been used back in Kansas, oil field? I can see it used in logging country out west.
Kevin
D2 5U13247 Direct electric start, #44hyd, 2S blade, Hyster D2N
Mon, Aug 5, 2013 5:54 AM
Reply to n7gxz:
Kevin
A company that strung cross country power lines may have used this type of winch or someone had a dragline or slurry bucket hooked to it.
Mon, Aug 5, 2013 8:18 AM
If both drums can be run simultaneously, you could skyline with it. If not, then just regular mainlining with the second drum as the backhaul (I'm talking logging). Guy I hauled from had a similar unit on the back of his D8 (2H?) that he logged with - the one with the T-shaped dash. Although, looking at the drum mounting collars, you'd only want to do light work with it. Still, that's a valuable looking piece of iron you have there - look after it! Seems the main things with these winches is to keep the bearings in good shape because the gears are made of unobtainium.
Mon, Aug 5, 2013 8:26 AM
Hyster single drum like that will drag the tractor backwards!😎
Mon, Aug 5, 2013 8:36 AM
qipp
Reply to n7gxz:
Kevin
[quote="n7gxz"]What would that have been used back in Kansas, oil field? I can see it used in logging country out west.
Kevin[/quote]
That is probably what it was used for as there is a lot of oil production in this area. My older brother bought the winch years ago after getting a tractor stuck. He couldn't pull it out with the D4 and had to hire someone to pull it out so he decided he would get the biggest darn winch he could find to put on the D4. This is what he come up with, a bit of overkill!
Mon, Aug 5, 2013 8:52 AM
Reply to qipp:
Kevin[/quote]
Here is some info on the D7 version that gives some idea of how it's built and what the uses are. Not very easy to read, been copied to many times.
Mon, Aug 5, 2013 9:24 AM
qipp
Good information, thanks for posting it.
Tue, Aug 6, 2013 7:46 PM
| Hartley - South Australia
