HT 4 Question
HT 4 Question
JackD6-5R
Is it possible to remove the highlift frame, lift arms & bucket assembly as one piece. Need to work on or change motor. Bearing cuttings in oil filter & losing oil pressure. Thanks for any ideas. Jack
Tue, Feb 18, 2020 2:02 AM
doylex
Send a private message to doylex
Quite a undertaking. Know a guy who overhauled one through the side cover. You'll want to get the lift arms up out of your way. Probably drop the track on the left also for more working room. (its only a $20 pin)
Most of the lower bolts that hold the frame to the hardbar and rear trackrame wont be fun.
If you have something big to lift with it is doable as I have fitted a t4 frame to a d4
Thu, Feb 20, 2020 7:59 PM
