First Cat project.
First Cat project.
Showing 1 to 10 of 14 results
Sf1066
Send a private message to Sf1066
This is my first post and first steel track project. A 5u D2. Has been sitting for a long time. both engines are free but no spark. I’m just getting started with it. I got the manuals and am learning. I will likely have questions so thanks
Sat, May 30, 2020 6:39 AM
timbo1946
Send a private message to timbo1946
Very nice. Looks like a nice machine
Sat, May 30, 2020 6:54 AM
GrantJ
Online
Thank you received: 13
You might disconnect the wire from the mag to the mag switch. Those switches are known to go bad and people rebuild the mag when that isnt the problem. The web site for OLD CROAK MAGNETOS has a huge amount of information on mags. I recently had them rebuild a mag and I am pleased with their work. Grant.
Sat, May 30, 2020 6:57 AM
Sf1066
Reply to timbo1946:
Well it’s not cherry for sure but has potential. After I get it running it will need some steering clutch work. I want to see how it runs before I get to excited
Sat, May 30, 2020 6:59 AM
Sf1066
Reply to Sf1066:
Thanks Grant. I was thinking about doing that. I have only spent a couple hours on it. Mostly cleaning the gas tank and some plumbing. Hope to start getting serious with it soon. Had some crap plug wires.
Sat, May 30, 2020 7:04 AM
GrantJ
Online
Reply to Sf1066:
You have to use solid core wires for magnetos. I have found that the new end pieces for the wire (90 degree) from Napa are not long enough, and tend to slip out. I need to call Old Croak and see were to get better ones. Grant.
Sat, May 30, 2020 7:31 AM
Fat Dan
Reply to GrantJ:
Welcome to the club
I use the site a lot and find info and parts that are hard to find. It's nice to be with like minded people. I picked up a couple Cat 955 track loader projects. Good luck
And might I suggest start by getting a service manual, a parts manual, operators & maintenance manual for a start. If you have a question about anything on a Caterpillar it will help to add the S/N number because correct Cat parts are all tied into the S/N. Hence, the need for the manuals so everyone is talking about the same part.
eBay has many of the necessary manuals.
Sat, May 30, 2020 8:08 AM
Sf1066
Reply to Fat Dan:
Welcome to the club
agree on the solid core wires. I got some already.
I was advised to get the manuals so I did already. The sn tag is not on the rear. So hope I can figure it out somehow. The tag is on the engine but I have no history on this unit. I did a fair amount of power washing today so maybe I can learn some more soon.
Sat, May 30, 2020 8:42 AM
Mike Meyer
Thank you received: 6
Reply to Sf1066:
Think about joining ACMOC too, membership is less than a pail of engine oil, or a service book, but the technical support and good friendship you get is worth tens of thousands of $$$$$$, plus we need the help to keep the Club going.
Sat, May 30, 2020 9:07 AM
d2gary
Reply to Sf1066:
haha if you bought a 5ud2 and want to learn you're already to excited
Looks like a good tractor
Looks to have the big front idler, is it a 5 roller
Sat, May 30, 2020 9:10 AM
Sf1066
Reply to d2gary:
Well I really don’t know what I have here. I know next to nothing about them what is good, bad or desirable. I got into it right and I’m a sucker for a interesting project. I am far more knowledgeable about Ag equipment. I look forward to getting it going. Not even sure what I’m going to do with it. I have a 3yr old grand son that is all about motors and levers. So I hope he likes it. That alone would make it worth it. I will probably;y still be working on it when he’s old enough to run it. Lol. Is there a list of good and bad features on these?
Sat, May 30, 2020 9:25 AM
