Draining a D4 7U for the winter.
Showing 1 to 10 of 21 results
Norm R2,22
Send a private message to Norm R2,22
I've drained the coolant (water) by opening the valve at the bottom right side of the radiator. Does that drain the whole machine including the pony? I don't see anything other than the cylinder drain cocks on the pony and nothing on the sides of the main engine. Am I missing something or did I get it all?😕
Sun, Dec 6, 2015 10:52 AM
Paso Bob
It's been a while since I have drained out a 7U, there is a plug to remove on the left side of the diesel engine block close to the injector pump area. It is by itself on the side of the block.
Sun, Dec 6, 2015 11:11 AM
cheshire cat
Send a private message to cheshire cat
Reply to Paso Bob:
The got ya on these and the d2 can be sludge and gunge blocks the water narrow passage under the pony so some water stays in it causing frost damage , if there is any doubt I would pull the pony heads and if there is gunk poke some wire thru it and then flush by filling the radiator....
Sun, Dec 6, 2015 1:56 PM
Reply to cheshire cat:
I am a firm believer in keeping the cooling system full with an antifreeze mixture to eliminate freezing and also to prevent oxidation and corrosion of the system
Sun, Dec 6, 2015 8:30 PM
cojhl2
Reply to dpendzic:
Absolutely! Expensive the first time but I never change it regardless of the manufacturers advice. Just add additive every Fall.
Sun, Dec 6, 2015 10:11 PM
willwingo
Thank you received: 8
Reply to cojhl2:
Here are pictures from Operator and Maintenance Instructions, form 12244-7.
There is a vent on the top of the starting engine that needs to be open when refilling to insure that water jacket on the starting engine is filled.
Mon, Dec 7, 2015 12:08 AM
Norm R2,22
Reply to willwingo:
I completely missed the block drain. I was looking for a valve or something that looked like one. I thought that "bolt" held something in the engine. With the water pump leaking, I didn't want to put 50/50 in the radiator and have it leak out. I suppose I could fill it, run it, and drain it into a container to be returned when the water pump is fixed. Or pour straight anti-freeze into the vent on top of the pony. I have a manual #104 and a parts book UEO32523, but none of them showed the location of the drain. I guess I'll have to get 12244-7 to get the full picture. Thanks for the information.
Mon, Dec 7, 2015 12:32 AM
Reply to Norm R2,22:
I got many gallons of used antifreeze from my auto mechanic for free as he always had to pay to get rid of it.Try some mechanics in your area and Pour that in the block and if it leaks out no loss! I filled my tractor tires for free that way.
Mon, Dec 7, 2015 5:07 AM
Norm R2,22
Reply to dpendzic:
I'll give it a shot. There has got to be some around that they want to get rid of. Thanks for the idea.
Mon, Dec 7, 2015 6:24 AM
STEPHEN
Reply to dpendzic:
That is a great idea, recycling !
Mon, Dec 7, 2015 7:28 AM
u-joint
Send a private message to u-joint
Reply to STEPHEN:
I have known liner O-rings to fail after sitting dry. always keep antifreeze in a wet liner engine!
Mon, Dec 7, 2015 8:26 AM
