Dozer Trunnion To Frame Bolt Part#
Showing 1 to 7 of 7 results
hotrodwelder1
Send a private message to hotrodwelder1
Greetings,
I'm mounting my tool bar blade to my D4 5T. I am looking for a part number for the trunnion bolts that thread into the track frame. I have searched all my books and manuals with no luck.. 1-1/8" Head and 3/4"-10 Thread with the taper.
I'm missing about 4 of these bolts and my local Cat dealer has no part number...
Thanks!
Mon, Oct 22, 2018 8:35 AM
josh
Thank you received: 13
3F6697, Cat or aftermarket.
Mon, Oct 22, 2018 9:09 AM
hotrodwelder1
Reply to josh:
Thanks Josh! as normal my dealer doesnt have them in stock....hahaha..
Tue, Oct 23, 2018 9:32 AM
d2gary
Thank you received: 51
Reply to hotrodwelder1:
If you find a source or if they're available from cat could you let me know. I have work on my 5t this winter and have some missing and not sure how the rest will come out
Tue, Oct 23, 2018 9:36 AM
hotrodwelder1
Reply to d2gary:
@ D2Gary, i just Googled the part number, it came right up. It was used as a wheel bolt also, so it seems very common. I will check with Dana @ Florin Tractor or CTP and see who has them. I need 4 or 5 more.. Last resort is run to Boise and get them off another machine at General Gear.
Tue, Oct 23, 2018 9:50 AM
josh
https://aftermarket.supply/caterpillar/3F6697.html
Tue, Oct 23, 2018 10:43 AM
If it is more convenient, that bolt or similar (length??) is used on larger JD farm tractors like 5020 and 6030 to hold the frame rails to thecside of the transmission, engine and front axle support casting.
Tue, Oct 23, 2018 6:46 PM
Paso Bob
Two years ago I purchased a full of bolts set for mounting Cat 4S side arm assemblies to my track frame. They were available from Cat and reasonably prices. Cat bolts from my experience are harder than after market bolts.
Thu, Oct 25, 2018 11:01 AM
