Difference in pony motors
Christopher
Send a private message to Christopher
Is there much of a difference between the pony motors on a d47u and a d42t? I wouldn't think they would have changed much. Is there a model number on the motors? And if so where should I look?
Fri, May 25, 2018 1:45 AM
cheshire cat
Send a private message to cheshire cat
No model number just part numbers making it up for the application , the main difference is the top manifold how the water outlet connects to the main engine , block and internals mostly same ... hope that helps...
Fri, May 25, 2018 2:15 AM
Christopher
Reply to cheshire cat:
Yes thanks. I am hoping to use the gas tank off the 7U for the 2T. Also, it would be nice to be able to save the other one for spares.
Fri, May 25, 2018 6:44 AM
