Diesel Fifty Oil
Diesel Fifty Oil
bruder9
Send a private message to bruder9
Need a rough estimate on amount and type of oil to put back in our Diesel Fifty. Pulled inspection plate to clean screen. Had less than 2 gallons come out even though showing full on dip stick. Thanks for any help.
Tue, Sep 8, 2009 4:17 AM
Oil Slick
b9, you want oils that meets the least standards. Try to avoid modern clean oils like Delo. Here is an oil I buy from Tractor Supply for $45 and meets very few standards.
Tue, Sep 8, 2009 8:35 AM
OzDozer
Reply to Oil Slick:
bruder9 - Here are the Diesel Fifty capacities .. 2 gallons is a little shy. I think you need to check that the dipstick is correct, correctly positioned, and correctly marked ..
Engine .. 11 qts
Transmission .. 32 qts
Final drives (ea) .. 16 qts
Cooling system .. 18.5 galls
Fuel tank .. 60 galls
Thu, Sep 10, 2009 8:50 AM
