D9G Torque settings
D9G Torque settings
Showing 1 to 7 of 7 results
Neil D
Send a private message to Neil D
Anybody got the torque settings for the drawbar studs of a D9G?
Tue, Sep 22, 2009 5:33 AM
bruce oz
Thank you received: 23
hello Neil ,the service book has not any torque for the draw bar bolts,if you post the bolts size i can post the torque for the bolt size ,bruce oz
1'' = 500-600 pound feet
1 1/8''= 675-825 pf
1 1/4''=860-1060 pf
1 3/8''=1050-1290 pf
1 1/2''=1260-1540 pf
Tue, Sep 22, 2009 6:15 AM
Neil D
Reply to bruce oz:
1 1/8''= 675-825 pf
1 1/4''=860-1060 pf
Hello Bruce
I am not close to the machine but I do know the nuts measure 2 3/8" across the flats- the studs are 1 1/4" diameter.
Hope this helps
Tue, Sep 22, 2009 6:44 AM
bruce oz
Reply to Neil D:
Hello Bruce
Hope this helps
hello Neil ,use this size for your bolts -1 1/4''=860-1060 pf,
clean all the surfaces ,sand rust off , ,put the bolts in the brackets ,leave bolts loose until the clevis and bolts are installed ,tighten bracket bolts(trans) first ,then clevis bolts.
bruce oz
Tue, Sep 22, 2009 7:09 AM
Neil D
Reply to bruce oz:
bruce oz
That is much appreciated imformation, thanks very much Bruce
Tue, Sep 22, 2009 7:11 AM
bluox
Reply to Neil D:
Hello Neil,
D-9G service book says 1 1\2" studs.
studs torque 550 lb. ft. nuts 1500 lb. ft.
good luck
Bob
Tue, Sep 22, 2009 9:02 PM
Reply to bluox:
Hello Neil,
good luck
Bob
Hi Niel,
Now ya'll got me looking.
Should be on that copy of the rear case parts diagram I sent you earlier.
I show the studs to be a #9S7479......unfortunately I don't seem to have a size chart up to that size to identify them with.
Universal torque chart.
Tue, Sep 22, 2009 9:40 PM
djcat
Send a private message to djcat
Hi Niel,
Looking in the D8K and the D9H manuals they say..
1 1/4" studs- 1000 +/- 100 ft lb for the nuts
1 1/2" studs -1800 +/- 180 ft lb for the nuts
Cheers djcat
Fri, Sep 25, 2009 5:53 PM
