D82u pony Part questions
Showing 1 to 6 of 6 results
Bennett53
Send a private message to Bennett53
Good evening everyone,
I recently had my rear main seize on my d8-2u pony motor. I’m having a heck of a time finding any replacements the book shows 3f-561 for the rear and 3f-562 for the front. They have been discontinued by cat and I’m struggling on next steps. I also discovered while I was in there that my rod bearings were on their way out. I was able to find those from cat luckily. Does anyone have a source I’m really trying hard to not go direct start. Thanks everyone
Sat, May 16, 2026 4:34 AM
gemdozer
I have some good used main bearing for the pony motor but can't find part number on and should have too the rod bearing
Sat, May 16, 2026 2:59 PM
brian18a
Thank you received: 62
look on Machinery Trader and search for 3F0561 and 3F0562. There are not many but there are a few. And is you crank Std size and condition good enough to not need grinding?
Sat, May 16, 2026 4:04 PM
gemdozer
HI I have a set on crankshaft but these are ,030 and have with 3f???? and have some other on with no number on.
Sat, May 16, 2026 6:08 PM
Thank you received: 61
I found with one of my D2s that there were plenty of std bearing shells available so I had my crank welded up so that I wouldn't have more of a challenge getting bearings
Sat, May 16, 2026 9:38 PM
clayton
Thank you received: 20
Hello were abouts you located at I have complete pony engines and parts in central Illinois?
Sun, May 17, 2026 10:59 AM
Bennett53
Thank you everyone for your help. Gemdozer i may reach out i was able to get a new old stock 3f-0561 on eBay looks great and now im going to gamble and pull off 3f-0562 see what it looks like.
Tue, May 19, 2026 1:00 AM
