D8 1H Track Interchange
Jeremy Williams
Send a private message to Jeremy Williams
Hi,
I have a friend that is trying to buy a 2u D8 for the engine possibly. He doesn't want the rest of the machine, but it has fairly good tracks on it. My parts book doesn't show the newer part numbers. The measurements on the dimensions seem to be fairly close considering the differences in wear. My Cat is an RD8 but it has had new sprockets welded on it. Does anyone know if they will all interchange or how to determine it?
Thanks in advance!
Fri, Nov 25, 2022 12:23 AM
Wombat
Donor
!H through to end 13A should all interchange, there will be some updates, however pitch and rail width etc will match.
Wombat
Fri, Nov 25, 2022 12:35 AM
Jeremy Williams
That is great news! i would really like to get my RD8 movable again. Its one of the first 125 or so tractors built. Do you know what all would need to be updated?
Thanks again!
Fri, Nov 25, 2022 1:01 AM
Reply to Jeremy Williams:
Thanks again!
I have some miscellaneous D75 and 1H parts, let me know if you need anything.
Fri, Nov 25, 2022 1:52 AM
brian18a
Thank you received: 70
Nothing should need updating. Only possible difference is RD8 has 38 links, if 2U is new enough with larger diameter idlers, it would have 39 links. If so one would need to remove one link.
Fri, Nov 25, 2022 3:43 AM
Jeremy Williams
Thanks again!
Thanks for all the information. I will see about getting the tracks if he buys the Cat. I will keep in mind the parts also Rome K/G. Thanks again!
Sun, Nov 27, 2022 8:22 PM
