D8 14A Pony Motor bearings
Showing 1 to 10 of 29 results
Treevor
Send a private message to Treevor
Hello!
My apologies If I am doing this wrong but I am looking for some information on some pony motor main bearings. I recently bought a D8 14A S/N: 14A6941. I cannot find a serial number on the pony motor but I really need to find some new main bearings for it. I will have to get the crank ground as it is rough. The last owner did not change the oil enough it seems and ran a long time with a lot of junk in the oil. I can't seem to locate bearings as I cannot find the serial number of the Pony.
Can I make some bearings out of straight aluminum stock just to get by for a bit? I have to run this machine for about a week to get some dirt moved for our house in the spring and then I can fix it up proper after that.
I appreciate any help offered!
Thu, Mar 6, 2025 11:03 AM
Thank you received: 29
Hi Trevor, you just need the tractor / engine serial number to get parts. The pony motor parts are described in the tractor parts catalog. We probably have the 14A series parts catalog in the Library on this site (need to join up as a member). You can also visit your dealer who may have someone old enough to be able to find the parts on their system. Yes, you can probably make some bearings.
Thu, Mar 6, 2025 1:28 PM
gauntjoh
Librarian
We do indeed have parts manuals for the D8 14A tractor in the Library, which are available for paid up members of ACMOC to view online and screen print individual pages (but not download the whole manual).
Visit the Store page on this site to buy a membership from just $44.
Thu, Mar 6, 2025 1:57 PM
Thank you received: 38
Reply to gauntjoh:
note some part numbers need a extra zero added to them so they show on the cat parts system. also ask your dealer parts staff to look under classic cat as some of the part numbers have been relocated to that range
Thu, Mar 6, 2025 7:56 PM
Treevor
Thanks for the reply Guys! I would have replied sooner but could not login due to the password reset. I found the S/N F25449 stamped on the block by the head and then painted over. Finning thinks this motor is not original but they can't find bearings in the 0.030 undersize for me anyway. Does someone have these bearings available?
Wed, Mar 19, 2025 8:23 PM
Treevor
I have received the same parts picture from finning and a second company but both pictures show a tapered gear on the end of the crankshaft. My crankshaft does not have this tapered gear. I would add a Picture but I cant figure out how to do that
Wed, Mar 19, 2025 9:03 PM
Treevor
Wed, Mar 19, 2025 9:04 PM
Trevor, that's not a serial number if it's on the pony - it's a casting number. There is sometimes a relationship between casting number and part number. If you can get a casting number from the crank, someone here may be able to tie it back to a part number. Your dealer is probably right that the pony is not original. "Ideally" the replacement would be a documented update from the original but it's well-known that ponys can often be adapted between the likes of D7s, D8s, and D9s of that era (and other types of equipment running similar engines)
Wed, Mar 19, 2025 9:16 PM
gemdozer
Thank you received: 12
The 14a poney motor block is 3h8025 or 9h6197 and the parts number is near the carburator and the maine bearing on side flywell is 8f3853 standar and 1h2753 =0.30 and rear end 8f3852 standar 1h2754=0.30
Wed, Mar 19, 2025 9:30 PM
Treevor
Ok. I have tried replying many times but always get "the new message field is required". what am I doing wrong?
I have also found those part numbers but cannot seem to locate any bearings from finning. The block has this number stamped under the carb 9M7710 Is this from a D9 dozer then?
Wed, Mar 19, 2025 9:38 PM
gemdozer
The block 9m7710 is for D8H and could have 2 different crankshaft 4s5352 and 3s5531 and check your crankshaft they use different part number
Thu, Mar 20, 2025 12:58 AM
