D8 14A Hydraulics
D8 14A Hydraulics
Treevor
Send a private message to Treevor
Just curious if anyone knows or has a schematic for the hydraulics on one of these machines? I noticed the other day that the blade was not lifting sometimes right away after a couple hours of work and if it did lift it was much slower than before. I am not sure which Hydraulic pump runs the blade. I believe the oil for the blade is in front of the radiator. Is there a pump by the radiator coming off the front of the engine? The lines for the cylinders go around and down under the radiator. Any help would be great!
Fri, Sep 19, 2025 7:01 PM
D8Dude
Thank you received: 24
Unless I'm mistaken, and it's the machine pictured in your profile picture, the pump will be driven directly from the front of the crankshaft. The pump, and valve, is located inside the reservoir inside the nosecone, in front of the radiator.
Fri, Sep 19, 2025 10:20 PM
Treevor
Ok. Thank you for that clarification. I kind of thought so but I did not have a chance to look at it yet. Would you know if there is a suction filter or relief valve in the circuit somewhere?
Fri, Sep 19, 2025 11:23 PM
D8Dude
I'm not certain without doing some research. I would start by confirming proper lever/linkage movement between the control lever and the hydraulic control if you haven't already. There's a few pins and pivots that get worn and don't transfer enough movement to the control valve.
Fri, Sep 19, 2025 11:45 PM
Thank you received: 29
I'm guessing that if you weren't sure where the pump and reservoir are, then the oil level hasn't yet been checked, so that's another item to look at (assuming you haven't yet). If it's like the #44 etc., then there's a filter in that unit on the front. Might be a good opportunity for a fluid change as well as filters.
Sat, Sep 20, 2025 12:37 PM
