D7 17A HYSTER D7D winch parts
Showing 11 to 11 of 11 results
2
Thank you received: 95
Hi TOP,
no, I tried copy and paste and that is the result.
I may have just cracked the sequence to copy and paste the actual printed answer--if my slow marbles can remember the sequence next time---well I never, here is the answer for you and others in future as synthetic ropes take over.
For Hyster towing winches, maintain a minimum of 3 to 5 dead wraps on the drum for steel wire rope and 8 dead wraps for synthetic (UHMWPE/HMPE) rope. [1, 2, 3]
Drum anchor points (such as ferrule pockets, wedges, or set screws) are only designed to hold the line during installation—not to bear the full line pull. Keeping these dead wraps on the barrel generates the friction needed to anchor the load safely. [1, 2]
Rope TypeMinimum Dead WrapsKey Hyster & Rigging RequirementsSteel Wire Rope3 to 5 wrapsAllied/Hyster W6F Operating Manuals specify an absolute minimum of 3 complete wraps to prevent the ferrule from pulling out of the drum pocket, with a recommendation to paint the last 5 wraps a contrasting colour as a visual stop warning.Synthetic Rope (UHMWPE)8 wrapsSynthetic fibres have a much lower coefficient of friction than steel. Rope manufacturers like Samson Rope and Australian SafeWork rigging guidelines require at least 8 wraps on the drum barrel to prevent slipping under load.
Critical Spooling & Installation Rules
  • Pre-tension during installation. Spool both wire and synthetic lines onto the drum under a back-tension of at least 10% of the rope's Working Load Limit (WLL). Loose base wraps allow upper layers to dive and crush the rope under heavy pulls. [1, 2, 3, 4]
  • Drum heat protection. If converting a legacy Hyster winch (such as a W5A, W6F, or D4-series) from steel to synthetic rope, install a high-temperature protective sleeve over the first layer of wraps. Internal drum brake heat can melt or degrade UHMWPE fibres. [1, 2, 3, 4]
  • Flange clearance (freeboard). Never overfill the drum; keep the top layer of rope at least 13 mm (½ inch)—or two rope diameters—below the outer edge of the drum flange to prevent the line from jumping off. [1, 2]
If you share your exact Hyster winch model (e.g., W5A, W6F, D4N) and rope diameter, I can give you the maximum drum line capacity and exact ferrule or anchor hardware specs.
Sun, Nov 22, 2026 11:30 PM
2
