D6d
andyindy
Send a private message to andyindy
Going to look at a D6D this week end. Owner has had it 20 yrs, says it is in top shape, just used on his farms. Any thing in particular I should look at, other than the usual wear areas? Any good/bad serial numbers? Thoughts? 12k hours. Thanks in advance, Andy.
Cat D8K, Cat112 3u grader, Cat 236 skid loader, JD 690 B hoe, Case (Can't Afford Something Else) 1150b, 450 dozer, 450 loader, 580c backhoe x2, 310f loader backhoe, Mack R model tractor w/ Rogers RGN My fleet of mostly working antiques. :crazy😛roviding a great living for the parts guys! :eyebrows:
Thu, Jun 14, 2018 10:08 AM
bursitis
D6D is a good machine. other than the obvious undercarriage issues you should check the engine for blow by and see if it will start from cold. also expect the belt pulley to be worn out and the engine to get hot on warm extended hard days work unless it has had a change.
Fri, Jun 15, 2018 12:26 AM
andyindy
Reply to bursitis:
That's a roger on the pulleys, never thought about that! Thanks for the reply. Andy.
Fri, Jun 15, 2018 3:34 AM
andyindy
Reply to andyindy:
Bought the D6d and now looking for engine enclosures and limb risers. Used or after market OK. Thx, Andy.
Mon, Jun 18, 2018 10:38 AM
