D6B Rod, rocker arm, or wrist pin noise?
Hdonly
Send a private message to Hdonly
Fri, Aug 23, 2019 3:40 AM
I thought I could hear a deep low pitched knock as you walked back behind the tractor the first time around, but later I didn't notice it and when you shut it down, I didn't hear a piston slapping the head. So unless you are hearing something else, I think you're still good. Doesn't mean it won't let go tomorrow, I just don't hear it now.
What does the oil pressure do at idle?
Fri, Aug 23, 2019 7:52 PM
Hdonly
I runs about 10 to 12 lbs at idle warm. What I hear sounds like a rocker arm to me. I haven't checks valve adjustment yet, but getting ready to pull the cover and do that.
Fri, Aug 23, 2019 9:24 PM
Dick Tucker_archive
Send a private message to Dick Tucker_archive
Reply to Hdonly:
Several years ago my D7 17A had a knocking noise that turned out to be a bad injector pump. Not sure if the fuel injector system on you D6B is similar to a D7 17A but if it is might purchase a new injector pump and try it in each position to see if it changes the noise.
Sat, Aug 24, 2019 12:21 AM
bursitis
Reply to Dick Tucker_archive:
try wraping your phone in a rag and redo the video. we won't be able to see anything but the rag will filter out most of the noise and let us hear the knock better.
Sat, Aug 24, 2019 12:44 AM
