D69u F/R Lever Position.
R W
Send a private message to R W
Can anyone advise the correct position for the forward reverse lever on a D69u when it is parked with the engine running, master clutch engaged, gearshift in neutral.
Thank You.
Wed, Nov 13, 2013 6:15 PM
chriscokid
you pull it back towards seat to go forward and you push it forward toward the engine to go reverse. Netural is in the middle.
Wed, Nov 13, 2013 6:48 PM
fordhook
Send a private message to fordhook
Reply to chriscokid:
I like to keep it in toward the seat (F) when the tractor is idling. This keeps the lower shaft turning for lubrication of the bearings.
Wed, Nov 13, 2013 8:11 PM
Thank you received: 62
Reply to fordhook:
I believe the operators manual says it does not matter if forward or reverse, but do not leave it in neutral as Fordhook stated.But it seems more out of your way in the forward position.
Ray
Wed, Nov 13, 2013 9:22 PM
old-iron-habit
Reply to Ray54:
Ray
Ray54 is correct on what the operators manual says. Either way but needs to be in one or the other at extended idling for lubrication.
Wed, Nov 13, 2013 10:01 PM
johan7
Reply to old-iron-habit:
Either way ? Yes , for lubrication of the upper shafts . BUT : long time ago in the army with 3T d7's (the same kind of transmission) they taught us to put it in forward when the machine was parked with the back to something and to put in backward if there was something in front of the machine . So , nobody will be surprised when someone will put it in some gear and move to the side where it should not move . And since I always handle this way . Safety first .
the Netherlands johan7
Thu, Nov 14, 2013 1:40 AM
Thank you received: 95
Reply to johan7:
as per scan below.
Thu, Nov 14, 2013 7:06 AM
DPete
Reply to edb:
as per scan below.
Pull back to go forward and push forward to go back, always wondered about that LOL
1962 D4C
Thu, Nov 14, 2013 7:55 AM
fordhook
Reply to DPete:
Now that was interesting to learn about the D8 transmissions
Thu, Nov 14, 2013 10:28 AM
