d69u
jw45
Send a private message to jw45
is the motor and machine number suppose to match like machine #d69u 22224would the motor tag be the same when manufactured
Wed, Apr 8, 2009 11:10 PM
SJ
Send a private message to SJ
Yes the older tractors like yours the SN on the engine was the same as the tractor but if an engine was installed from another tractor then it would be different.Later D6 tractors the engine had one number and the tractor another. Take say one model of a D6C the engine was a 3N 3306 engine SN and the tractor was 10K SN starting in 1967.
Thu, Apr 9, 2009 2:05 AM
jw45
Reply to SJ:
now if i want parts for the engine i should use engine #and not the machine #on back of machine thanks
Thu, Apr 9, 2009 8:29 AM
Roland
Send a private message to Roland
Reply to jw45:
Yes... but if you need ancilary parts some may be different so it would be good to have a parts book that covers both SNs so you can compare....
hope this helps...
Thu, Apr 9, 2009 2:09 PM
