D6 9U starter video
D6 9U starter video
King of Obsolete
i whipped up a simple video on the starters on my D6 9Us with the help of Old Magnet and this BB. thansk
https://www.youtube.com/watch?v=z-DigvkLFMw&t=62s
Tue, Sep 8, 2020 7:34 AM
oldbeek
Did you know they make a 12point (9/16 head) X5/8 bolt for bolting on the starter? Just look up 12 point cap screws. Handier for the inside bolt because the 12 point will hang onto a 9/16 socket and long extension during install. May have helped on your close clearance bolt.
Sat, Sep 12, 2020 11:57 AM
Things have changed......
Current best approach for the awkward mounting bolt that required some grinding is to use a 5/8 x 1-3/4 button head cap screw and a cut down 3/8 allen wrench. This method requires no grinding as I have found that some of the China knock-off starter casting are too thin to accommodate any significant grinding without going through the casting.
Sat, Sep 12, 2020 11:56 PM
