D6 9u serial number location
fbksfiddler
Send a private message to fbksfiddler
I am purchasing a d6 9u and can't find the serial number. Any help would be appreciated
Sun, May 11, 2025 7:57 PM
gemdozer
Thank you received: 12
The serie number is on side motor not far from master cluch and on rear housing he should have a tag with serie number
Sun, May 11, 2025 8:15 PM
Left side standing behind tractor, top of the transmission case, just a bit lower than the top of track. A brass tag held with 4 rivets. If tag is gone clean area well inside the holes where rivets use to be, it is stamped in the steel. If there is a winch or other mounted equipment it maybe covered. It is also on the left side of engine block, just in front of the pony mag. Again brass tag, and stamped under the tag. Also stamped into the left side flange of the engine oil pan, if the pan is still original.
Sun, May 11, 2025 10:50 PM
