d6 9u Diesel Tank Repair
doc_dozer
Send a private message to doc_dozer
I'm going to remove and repair the seat tank before winter sets in. The top of the tank where the seat sits is heavily rusted and pitted so I am going to drain the tank, remove and flush it, then cut out rusty part of the top.
Before I get started does anyone know off hand how thick the material is? I am guessing it's close to 1/8".
Thanks!
Charley
'44 D2 5J 6987SP
'57 D6 9U 25158
and bunch of Farmalls😉
Sat, Sep 23, 2017 12:20 AM
rmyram
its a little thicker than 1/8, King of obsolete has docuemented some seat tank repairs on 9u D6's, can't remember if it is on here or his website, Kingofobsolete.ca
Sat, Sep 23, 2017 12:28 AM
doc_dozer
Reply to rmyram:
Thank you, i'll check here and in the kingdom for it!
Charley
'44 D2 5J 6987SP
'57 D6 9U 25158
Sat, Sep 23, 2017 7:23 AM
King of Obsolete
Reply to doc_dozer:
i can check in the morning because i have a tank open. also i think there are baffles in the tank too, will check that too.
thansk
KoO
Published Author
Sat, Sep 23, 2017 8:18 AM
doc_dozer
Reply to King of Obsolete:
thansk
KoO
Published Author
Thnk you! I checked this site and yours but haven't found any references to metal thickness. I jest need to cut a square out on either side of the central tube. I'm sure the tank needs to be cleaned anyhow.
Charley
'44 D2 5J 6987SP
'57 D6 9U 25158
Sat, Sep 23, 2017 5:35 PM
