D6 2H clutch
D6 2H clutch
svoght
Send a private message to svoght
I have to take the clutch out of a D6 S/N 2H 7265W. Is there a way to get this done with out taking the engine loose? If any one knows, I would apprieciate your input. Thank you, Sam
Tue, May 12, 2009 6:36 PM
OzDozer
Sam - Do you have to remove the entire clutch assembly, or just need to replace the drive disc? You can do the latter job in-situ, but anything more requires the engine to be unbolted and moved forward.
Your tractor is fitted with the improved, later design clutch, with a 2-piece disc, that allows the disc to be removed after just the transmission case cover is removed. Here is a SM article that will assist ..
Page 1 - http://img254.imageshack.us/img254/7892/rd6clutch1.jpg
Page 2 - http://img254.imageshack.us/img254/7423/rd6clutch2.jpg
Tue, May 12, 2009 8:58 PM
svoght
Reply to OzDozer:
Ozdozer, Thanks for the information. I didn,t realize it was a two piece clutch disc. The problem is the teeth are stripped off of the clutch disc, so if any body has a good one...... You can always be depended on for good information Ozdozer!!! Sam
Wed, May 13, 2009 3:24 AM
