D47U trans bearing
D47U trans bearing
kracked1
I have a D4 7U8869. The front bearing is starting to make a little noise. Is it possible to change that thru the clutch inspection hole in the top of the bell housing? Or do I have to pull the top cover off the transmission? I looked at the book and it shows how to get it apart. Just not if you can do it without pulling the top cover.
Sat, Jul 10, 2021 7:07 PM
The cover will have to come off to get in there.
Sat, Jul 10, 2021 7:53 PM
kracked1
Thank you. I was hoping not to have to pull it. But if I do I do.
Sat, Jul 10, 2021 8:10 PM
rax200
Hi kracked1,The noisey bearings in the box could be the one inside the front input shaft, there are only five bearings in the box if you go in to do one you might as well do all of them.
I have done several boxes now and for a few hundred dollars It is good insurance.
You will require the following
2 x 6308
1 x 6313
1 x 6309
1 x AB1307
1 X M1307TV
 Plus gaskets
Regards
Sun, Jul 11, 2021 6:27 AM
kracked1
Reply to rax200:
2 x 6308
1 x 6313
1 x 6309
1 x AB1307
1 X M1307TV
 Plus gaskets
Regards
Rax 200 thank you much. It looks like a winter project.
Mon, Jul 12, 2021 9:04 AM
