D4600 Piston Ring End Gap
sheddcanyon
Send a private message to sheddcanyon
Would anyone have the piston ring end gap specs for a D4600? I have new cylinder sleeves and NOS rings.
My top ring gaps are .019" to .020" (5B905)
All middle ring gaps are .010" to .011" (6B2172)
My oil rings go haywire, .021", .022" and 4 above .025" (6B2134).
Thanks for the help.
Sun, Jun 20, 2021 4:45 AM
Caterpillar Engine Specifications data sheets.
As you can see Cat place most emphasis on piston ring side clearance in the grooves.
My old Apprentice Schooling work book tells me that if makers specs. are not availble to use a figure of :-
0.003" to 0.005" per inch of diameter of the cylinder bore.
Hope this helps.
Sun, Jun 20, 2021 7:48 AM
I only have specs for the 4.5" bore engines but the 4-1/4" bore isn't going to be much different.
 [attachment=63712]4 half bore end gap.jpg[/attachment]
Sun, Jun 20, 2021 8:43 AM
sheddcanyon
Eddie, your info matches the D4600 Service Manual specs. Based on the .003 -.005 rule from your Apprentice Book, I'm out as much as .006 -.007 on the end gap on 3 rings. I think I need to find more oil control rings. I'm buying them from Florin and it's hit and miss. They are double-wrapped in wax paper and have cosmoline that's harder than concrete. I've broken three already trying to get them cleaned up.
Thank you Eddie and OM for the information.
Sun, Jun 20, 2021 10:38 AM
kittyman1
Reply to sheddcanyon:
agree with previous posts...top rings .004" per inch of bore is adequate...the lower rings not so serious(less heat)...usually get away with less clearance..but go to safe side..go with piston and ring recommendations..
Sun, Jun 20, 2021 12:36 PM
Newby Hall Tractor Fest
