D4 starting motor
D4 starting motor
michael J. matsago
Send a private message to michael J. matsago
Does anyone know if the starting motor from a D4 serial number 7U 9309 would interchange with the starting motor from a D4 serial number 5T232? Thank You all in advance and Best Regards MJM
Fri, Dec 1, 2017 4:44 AM
gemdozer
Thank you received: 25
Yes the starting engine is interchangable maybe you need change the top manifold
Fri, Dec 1, 2017 6:13 AM
STEPHEN
Reply to gemdozer:
You will need the manifold for the D4400 application.
Fri, Dec 1, 2017 6:56 AM
