D4 Ht4 gasket
D4 Ht4 gasket
Showing 1 to 10 of 10 results
Cobalt Kid
Send a private message to Cobalt Kid
Gentleman,
My d47u has developed a oil leak between the rocker arm/ valve assembly housing and the head. I don't have any problem with the instructions as to removing it, but my concern is when I do lift it off will it be under tension by the valve springs and will I have a problem with reinstalling it.
Please reply,
Thanks,
Cobalt kid
Mon, Jun 11, 2012 7:45 PM
If I understand correctly, you are asking about removing the valve cover to replace the Cork gasket?
There is no spring tension on that cover. Go ahead and take it off.
Jeff
Tue, Jun 12, 2012 12:40 AM
Cobalt Kid
Reply to drujinin:
Jeff
Drujinin,
Sorry if I did not make myself clear enough. The valve cover sits on this housing. This housing encases the valves springs, rocker arms and the shaft that is used to compress the valves for the run/start lever. Under this encasement is the gasket that I am referring to. It leaks quite abit so I am wanting to change it. In the book it comes off as a unit( shows picture) but says nothing about the valves. So my question is, will I have to reset the valves once it is taken off, or can I just slap it back on and will be good to go?
Tue, Jun 12, 2012 2:08 AM
Willie
Reply to Cobalt Kid:
Drujinin,
What I think he is talking about is on the U ser. D4 there is a Valve cover that goes on top of an alum. riser between the top of head and and the valvecover and the valve mech is not conected to it in any way its just a riser around everything,with gasket on top and bottom
Tue, Jun 12, 2012 2:24 AM
Cobalt Kid
Reply to Willie:
Good day Willie,
I scraped the housing and you are correct about it being aluminum.
I guess I will start taking the outer bolts off first and see how it pans out.
Thanks,
Cobalt Kid.
Tue, Jun 12, 2012 7:46 PM
TimMcAfee
Send a private message to TimMcAfee
Good day Willie,
Thanks,
Cobalt Kid.
You will need to readjust valve clearance after you replace aluminum housing. Make sure you disconnect the oil line for the rocker shaft before you lift housing. Also you need to unhook linkage for compression lever. You dont need silicone sealer on the gasket, It may cause gasket to squeeze out when you tighten bolts
Tue, Jun 12, 2012 8:27 PM
Cobalt Kid
Reply to TimMcAfee:
Tim,
Is there any distinct position, or reference point (TDC, BDC ) as to which piston( 1,2,3,4 ) or valve (intake,exhaust ) should be, before undoing the bolts and nuts for this proceedure for ease of reassembly.
Thanks,
Cobalt Kid
Tue, Jun 12, 2012 10:24 PM
TimMcAfee
Tim,
Thanks,
Cobalt Kid
It doesn't matter what position your engine is in. You may want to loosen rocker adjustment before reinstalling rocker housing. After it is bolted down, you will need to adjust rockers. When I did mine I adjusted them to about .012" or .013" cold. Start engine and bring it up to operating temp and Readjust to .010" Make sure both valves are completly closed when making adjustment.
Wed, Jun 13, 2012 9:31 PM
Cobalt Kid
Reply to TimMcAfee:
Tim,
Thanks for the help. When cleaning the area for removal I noticed the gasket has either blown out or squeezed out about an inch or so at the end corner where the decompressor lever enters. Can this gasket be made? It feels like rubber by the touch.
Kid
Thu, Jun 14, 2012 12:42 AM
TimMcAfee
Tim,
Kid
You could make it if you had the right gasket material. I ordered mine from Cleveland Brothers Cat. In erie Pa. 814-899-2577. I was amazed how many parts they found for my old ht4
Thu, Jun 14, 2012 7:36 PM
Cobalt Kid
Reply to TimMcAfee:
Ok,
Thanks again for all the information Tim. Will check them out.
Kid
Fri, Jun 15, 2012 8:22 PM
