D4 foot plate bends
D4 foot plate bends
Showing 1 to 6 of 6 results
Haus
Send a private message to Haus
 Would somebody mind measuring where the bends in the foot plates are for me? I've cut out some replacements, but the originals are now flat (I didn't record where the bends were).
 [attachment=73975]IMG20230916181407.jpg[/attachment] [attachment=73976]IMG20230917190034.jpg[/attachment]
​​​​​​Paul.
Thu, Oct 5, 2023 12:17 PM
Haus
....simple distance from the front of each plate would be good enough.
Paul.
Thu, Oct 5, 2023 12:19 PM
Mschwartz
Reply to Haus:
Paul.
What model D4? I have a 7J and a 7 U that I could try to measure for you.
Thu, Oct 5, 2023 10:33 PM
willwingo
Thank you received: 8
Reply to Mschwartz:
Those floor plates are flat - no bends. (7U D 4's: 7U40602 and 7U40431)
Fri, Oct 6, 2023 2:17 AM
Thank you received: 52
Reply to willwingo:
they do have a slight bend well my 6u does.
Fri, Oct 6, 2023 9:15 AM
josh
Thank you received: 13
Reply to trainzkid88:
Just checked D47U 36,475 no bends, and early model D4s appear to be the same, D2s have bends on the ends.
Fri, Oct 6, 2023 10:45 AM
Haus
Reply to josh:
Mschwartz - these are for a 29A/6U D4. Sounds like I need to fit up to the tractor first as maybe they don't need bends.
willwingo, trainzkid88, and josh - thankyou very much for checking. I'll leave them flat for now and only bend them if they don't fit up without bends. I had thought the originals had subtle bends, but I can't see why they would be different to those on 7U 36475.
Paul.
Fri, Oct 6, 2023 12:17 PM
