D4 7U track interchange
noaht4
Send a private message to noaht4
Hi just pick up a 1959 D4 7U tracks on it are pretty well shot. Im new to crawlers it has a 6.75 inch pitch but not sure what other measurements have to be the same. Anyone know any other machines that use the same tracks? Also i see Alibaba makes dozer tracks are they any good? I know for  normal dozers theyre probably junk but for home use would they be ok? Also where do you buy new sprockets or i saw there’s weld on teeth sections to weld on top of a worn sprocket? Not sure if that’s still a thing or not. Thanks
Sun, Mar 2, 2025 8:20 PM
Thank you received: 42
Cat parts are more plentiful than the other brands, so I would think they will be easier to find than a make fit solution. Life could be so much easier if track chain was standardized, but it is not. Every company made it just for themselves. I have not looked for track parts in years so no idea what could be available from aftermarket sources today. In the old days Berco was a quality product, as well as several other companies.
Mon, Mar 3, 2025 5:31 AM
Thank you received: 47
Reply to Ray54:
last time i looked ITR had a listing 4 older d4 stuff whether it stayed the same all the way through or not i dont know. of course you can try the dealers if you have a part number ask them to check the classic cat part listings too.
the sprokets can be rebuilt by welding its a slow process. one method described forming suitable steel barstock as a liner and welding that in place. how they used to be done by the dealers was weld a new sprocket ring onto the existing hub and spokes
the later model d4 stuff has the same pitch but the bushing are larger might not be a big deal if your sprockets are worn.
the grouser plates have larger bolts on later models so you would have to drill them out or use later model grousers.
Mon, Mar 3, 2025 3:31 PM
