D4 7U gaskets
D4 7U gaskets
7FB
Send a private message to 7FB
Hello all. Just wondering if there's an aftermarket supplier somewhere here in the West for the gaskets on the transmission/rear end on a D4 7U, specifically the 3B0882 gaskets. The local dealer says they can't get them- something to do with tariffs?? Thanks in advance
Thu, Dec 18, 2025 4:14 PM
Thank you received: 54
try ohlsons gaskets.
Thu, Dec 25, 2025 1:13 AM
7FB
I did end up finding a NOS set from an outfit in the East. Earlier I had gone on the Olsen website but only saw engine gasket kits. Since you replied, I did look again and read the fine print, which says that they can custom make seals. Thanks for your help!
Thu, Dec 25, 2025 5:50 AM
KVollert
Send a private message to KVollert
When I rebuilt mine two years ago. I went through a similar search. For some items Cat has parts available. For everything else give Olsen's a call. There a a number of variants used over the years and the are great about working with you to get the right product to fit your application.
Cheers Keith
Fri, Dec 26, 2025 8:33 PM
