D4 7u cylinder identification
Showing 1 to 9 of 9 results
CodyKroeker
Send a private message to CodyKroeker
I’ve looked through some of the books I have and I’m not able to identity the cylinders I have I also did a google search and the show up as a John Deere number? But look like every other cat cylinder
Sun, May 10, 2026 2:11 PM
Thank you received: 54
might be the same size. i rebuilt a compair compressor once with rings from a mazda.
Sun, May 10, 2026 2:28 PM
Thank you received: 62
I think you included a picture my computer is not wanting to open. So a little more detail of what you are cross referencing would help me a lot.
Mon, May 11, 2026 12:57 AM
CodyKroeker
Tue, May 19, 2026 4:00 PM
Thank you received: 95
Hi,
maybe a description of what this cylinder does on your D4 7U. Kinda looks like it could be a No 4 Tool Bar cylinder??
If it is, most any decent hydraulic supply shop should be able to help you out at a guess.
Wed, May 20, 2026 3:20 AM
CodyKroeker
It’s for a small blade
Wed, May 20, 2026 2:03 PM
Not sure about this case, but generally the casting number is not the part number.
Taking what edb said if we have a copy of D4 tool bar equipment in the library here you could look for a part number there.
But I have had good luck with hydraulic supply house measuring the old seals and mostly have them in stock.
Wed, May 20, 2026 3:57 PM
brian18a
Thank you received: 70
The 4H6711 cast in the part is the cylinder group number. Npr says it applies to D2 and D4 tool bar serial numbers 71C 72C 73C 74C So a parts book for these tool bars should should provide info.
Wed, May 20, 2026 5:09 PM
Wed, May 20, 2026 8:16 PM
brian18a
Thanks OM, I could find my tool bar books
Thu, May 21, 2026 12:44 AM
