D4 5T front hyd pump mount
Showing 1 to 10 of 12 results
hotrodwelder1
Send a private message to hotrodwelder1
I'm looking to mount a hyd pump on the front of my D4, It's an aftermarket pump, not CAT. Does anyone have any info or ideas on doing this?
Fri, Apr 13, 2018 11:01 AM
Probably 10 years ago from a fellow in Colorado who was building/fabricating a mount and drive for the front of a D2/D4.
He worked on it when he was home (traveled a lot). I don't know if he ever finished it?
Fri, Apr 13, 2018 6:06 PM
hotrodwelder1
Reply to drujinin:
Would you know or have any info on this Colorado guy?
Fri, Apr 13, 2018 11:52 PM
hotrodwelder1
I hope so Garlic Pete... I would like some pics and ideas.. I asked for rear mounted pics a while back but decided to go off the front to have "live" hydraulics instead..
With that; any front pics are encouraged.. I have all weekend to Plot, Plan and scheme..hahaha..
Sat, Apr 14, 2018 9:55 AM
43gpw
Send a private message to 43gpw
Reply to hotrodwelder1:
My D4 5T has an aftermarket pump off the front, previous owner install. Also aftermarket blade was installed.
I can get you some pictures, but the bad part is I won’t be able to till first part of May
Live hydraulics are great, makes life a whole lot better
Russ
Sat, Apr 14, 2018 6:55 PM
hotrodwelder1
Reply to 43gpw:
Russ
[quote="43gpw"]My D4 5T has an aftermarket pump off the front, previous owner install. Also aftermarket blade was installed.
Russ[/quote]
That would be great Russ ! When you can is fine with me as i am not in a big hurry....... Thanks!
Chris
Sat, Apr 14, 2018 11:21 PM
657cat
Send a private message to 657cat
Russ[/quote]
Chris
The one on my 7u is a flat plate with a pilot to center the pump on the crankshaft. The pump is keyed to driveshaft the other end is bolted to the crank pulley. The shaft has a splined slip in the middle. The first is the rear mounted one on my 9u
[attachment=48092]11DBCC9C-E60B-4283-AE5D-CB4B3A1308C0.jpg[/attachment][attachment=48093]2AA86E2B-3846-44A3-A1D3-D92AF89A1B51.jpg[/attachment]
Sun, Apr 15, 2018 6:47 AM
Mike Meyer
Thank you received: 6
Reply to 657cat:
From Downunder, this is my RD4 which will be the same as your 5T, I set it up with rear remotes so I can disc with her which I'm doing right now, I reckon this pump runs at around 1,200 PSI when I tested it last year.
Mike
Sun, Apr 15, 2018 6:56 AM
Mike Meyer
Reply to Mike Meyer:
Mike
This is the drive plate my Fitter and Turner neighbor made for me to fit a #41 pump on the front of my D2 5U, it drives a similar coupler as the RD4.
Mike
Sun, Apr 15, 2018 7:07 AM
cojhl2
Mike
I guess I'm the Colorado guy,, I'll find the thread and pics. This was for a 5J.
Sun, Apr 15, 2018 9:49 AM
cojhl2
Reply to cojhl2:
I found the the thread, hopefully this points to it.
http://www.acmoc.org/bb/showthread.php?17975-Hydraulic-Pump-on-5J
The complete thread is worth reading as many members participated and provided very good information and examples of their installations.
I did make a change after installation, I moved the pump back toward the radiator by changing the mounting bracket.
The reason I used a bracket is because my tractor had only a sheet metal radiator shell and I did not think it was structurally sound enough to hold the pump.
Sun, Apr 15, 2018 11:46 AM
