D2/D4 pony motor pinion clutch and brake plate specs
Mike Meyer
Thank you received: 6
I need to pull the pony pinion on my RD4 and give it some TLC, because as long as I've owned this old girl, it has always been a challenge to get the pinion engaged without a bit of gear grinding, the brake does work, but only just, and now the pinion latches are out of adjustment, so it's time to fix it.  Does anyone have the thickness specs for the clutch and brake plates in one of those, like the worn out, and new thickness?
Mike
Tue, Jul 23, 2024 12:24 AM
