D2 steering clutches supplier?
Arborigine
Send a private message to Arborigine
I fired it up today and re-bled the diesel system, drove it around for a couple of hours and pushed some dirt around, and pushed against an immoveable object.
My left steering clutch is still stuck. I have little hope for it, as when i went to adjust the thing last week I found that the adjusters were set beyond the normal range, the wrench flats were actually inside the split nut of the arm. I set them as far as possible but the left arm actually touches the inboard edge of the casing, so I guess that's all I can do.
Does anyone have the part numbers for the clutch plates so i can shop them? has anyone had luck replacing the plates without removing the outer cage from the outer housing for alignment before assembly?
Thanks.
Mon, Apr 4, 2011 7:17 AM
JasonPayneCrawlers
This is were we got ours from. They worked fine and fast shipping👍 Hope this helps
http://www.steeringclutch.com/
Mon, Apr 4, 2011 7:44 AM
Steve A
Reply to JasonPayneCrawlers:
Before you order parts consider the thrust bearing, either way you have to tear it down for inspection, one of the parts D2s that I scraped only had 3 rollers left in the thrust bearing when I opened it up
Mon, Apr 4, 2011 8:08 AM
