D2 Rear main seel
D2 Rear main seel
2bluejon
Send a private message to 2bluejon
Well i have the motor out in my d2 and with it sitting ther, their is some oil running out from in behind the ting gear and i was wondering what i should do with that do i fix it or do i leave it alone and just drain the oil out of the cluch hosing when i rember. If i need to fix what does it entail to fix and also i do not have the packing # again it is on a D3400 motor thanks
Wed, Apr 29, 2009 1:33 PM
SJ
Send a private message to SJ
Usually why they leak back there is the rear main bearing is worn and possibly the crank journal too but many times just a new main bearing and new 2B2414 packing will correct the leak problem. When the bearing is worn you can tell where the screw area of the crank rubs the bearing at the rear, (back side) of it,s surface leaving it,s wear.I have seen this problem dozens of times with this type setup at the rear bearing.Most of the older Cat engines had this setup till they went to another type sealing back there,some had a piston ring type sealing and others a lip type seal.
Wed, Apr 29, 2009 6:15 PM
Reply to SJ:
If it's sitting off of level, not running, you will see some leakage even if it's not worn at all. It just can't keep oil in under those conditions.
Wed, Apr 29, 2009 6:37 PM
SJ
CC, I guess if the tractor was full of oil and tipped back far enough it might leak some but running that is why the threads are on that type crank setup to screw the oil back in the pan.As I stated if it leaks running then the bearing surface is worn at the area of the threads on the crank and the rest of it too so the threads then won,t screw the oil back in the pan due to too much clearance at that area.
Wed, Apr 29, 2009 6:47 PM
