D2 oil cooler
D2 oil cooler
1951D2
I have a friend that has a 5U 270.. D2 with an oil cooler leak He is wondering if he can just plug the lines after unhooking it from the cooler?
Sun, Sep 20, 2026 11:57 PM
d2gary
You can plug them but you have to go into the filter housing and do some stuff if you just loop them around you do don't have to t this is what I did on my d2 if you just Lipe them around you don't have to do anything
Mon, Sep 21, 2026 1:30 AM
1951D2
  1. Thanks so much d2 gary
Mon, Sep 21, 2026 1:48 AM
Thank you received: 95
as said above you can loop the lines and there is no need to change anything else.
This is how one member did it years ago.
Mon, Sep 21, 2026 5:50 AM
