D2 5U Pony Motor Starting Gear
Showing 1 to 7 of 7 results
jk
Send a private message to jk
Hi. Does anyone know if the D2 5U Pony Motor Starting Gear is replaceable ?
Tue, Aug 26, 2025 5:59 PM
jk
Just to clarify , this is the gear on the starting motor that is used to start the pony motor.
Tue, Aug 26, 2025 6:01 PM
Thank you received: 78
I've had that apart so it is replaceable I think. Probably only used parts available at this stage
Tue, Aug 26, 2025 10:21 PM
gemdozer
Thank you received: 25
If you are talking about the gear 7f8667 in the shield yes she can be replacable
Tue, Aug 26, 2025 11:03 PM
Thank you received: 54
do you have one that could be copied? with a indexing or dividing head and a milling machine one could be made.
Thu, Sep 4, 2025 4:52 AM
jk
Hi. no its the gear on the electric starter for the pony that engages when the starter spins up.. the electric starter motor pinion that I am wondering if it comes off and is replaceable. thanks
Sat, Aug 22, 2026 11:01 PM
Thank you received: 95
The gear is part of the 9B8949 Gear and Shaft Assem. as shown in scan attached.
Sun, Aug 23, 2026 12:04 AM
josh
Thank you received: 14
Sun, Aug 23, 2026 6:02 AM
