Correct oil for hydralics on D6B?
Jbayer
Send a private message to Jbayer
Is it supposed to have hydraulic oil or straight 30w? It is a vain pump. The wet clutch is 30w according to the tag. Also the transmission fliud, someone told me it is the same as engine so 15w-40?
Mon, Jul 25, 2011 11:34 AM
catsilver
The instruction to use engine oil came from the days when we used 30W before the days of 15W/40. The proper oil for hydraulics is 10W hydraulic oil, unless you are in a very hot climate when 30W is OK.
Mon, Jul 25, 2011 7:10 PM
bob
Send a private message to bob
Reply to catsilver:
Engine oil is okay in the hyd system but always use TDTO in anything with a clutch. Flywheel clutch, steering clutches or powershift trans. Hystat machines need Advanced 10 Hyd oil in the drive system.
Later Bob
Mon, Jul 25, 2011 7:47 PM
