Colour for Caterpillar twenty?
Showing 1 to 10 of 16 results
pds
Send a private message to pds
hi guys im working on my 1928 caterpillar twenty restoration (L294) i want to take it back to the original grey and red colour and wanted it to be the right grey and red?i found a article online saying (Federal Standard595B-26134) for the grey and (Federal Standard 595B-11120) for the red has anyone used these colours or have any other insight?
i wanted to try and get it right the first time loli can see grey in nooks and crannies and it looks like a battleship grey?  darker and little more blue then some i see online
i was planning on stripping the track frames and radiator leaving the finals transmission and motor still assembled then sand blasting and painting?thankspaden
Wed, May 25, 2022 12:27 AM
lomaberndsen
Send a private message to lomaberndsen
The ACMOC store on this website has the correct sample colour for the grey.
Wed, May 25, 2022 4:42 AM
SoCalCatMan
Send a private message to SoCalCatMan
Reply to lomaberndsen:
Does the gray change between models in this color scheme time period? Is the paint color on acmoc the end-all color for all early cats?
Wed, May 25, 2022 11:53 PM
Mike Meyer
Reply to SoCalCatMan:
When I did my 1928 built Cat 2 Ton, I found Battleship Grey to be a excellent match to the original colour.
Good luck with your restoration.
Mike
Thu, May 26, 2022 1:09 AM
pds
im wondering that too? the grey under yellow on dozer i can see looks like it has more blue in it but who knows maybe its a primer
i found and like the colour in acmoc store but it doesn’t match the grey i can see perfectly
Thu, May 26, 2022 10:13 AM
Mike Meyer
Reply to pds:
The old paint I found in hidden places on my 2 Ton had more blue in it, definitely was not like the color card, that's why I went with the Battleship Grey.
Fri, May 27, 2022 1:28 AM
pds
Reply to Mike Meyer:
interesting! do you have a photo of your 2 ton?
Sat, May 28, 2022 8:49 AM
Mike Meyer
From 2012 when I finished her
[attachment=67906]P1010063 [800x600].jpg[/attachment] [attachment=67907]P1010069 [800x600].jpg[/attachment] [attachment=67908]P1010071 [800x600].jpg[/attachment]
Sun, May 29, 2022 1:32 AM
pds
Reply to pds:
wow! that looks great! yours and mine might have been in factory together?mine is an early 1928 i believe around the 244th twenty built in San Leandro that year (L294 and i think L1-50 were built in 1927)
it makes sense that we have a similar grey
(i wonder if the grey was different between san leandro and peoria)
(*edit looking the 2 ton up and it looks like its from peoria)
Sun, May 29, 2022 2:25 AM
pds
Reply to pds:
on another note, where would u find the serial number on your 2 ton? theres one on a lawn nearby i wanted to check
Sun, May 29, 2022 2:27 AM
SoCalCatMan
Reply to pds:
I believe the tag on the backside of the seat shows the serial#. It’s a brass plate about the size of a piece of paper. I’m not sure about the two tons with the metal bucket seats though. If that one is missing, there should be a tag on the right side of the transmission below the shifter that might have it.
Sun, May 29, 2022 5:51 AM
